Part Numbers?
uk
2016 crdu bluedrive
I have a 66 plate santa fe crdi bluedrive. it is s 7 seater with a manual gearbox and type a engine. (no hole in the block) Unfortunately it has had a small burn near the abs pump someone has tried to cobble a replacement control wiring loom into it, it is not the correct loom. Hyundai want c£5k for the loom and will not give me the part number for the correct loom so I can try to find 1 from a breaker. If I can't then I will have to right the vehicle off. Would anyone with a similar vehicle be prepared to look up the part numbers from their fuse box? Un fortunately you may have to loosen the bolts holding the ecu as the labels are in between them. The ecu type (so I can check if that has been swapped too) would also be useful. Thanks for reading, and I would be very grateful to anyone willing to help. I am very disappointed that hyundai wont share the part numbers and this is a good vehicle, too good to scrap IMO.
